[GRASS-dev] Problem using r.in.xyz (nodata)
Roberto Marzocchi roberto.marzocchi at gmail.com
Wed Jul 17 04:26:02 PDT 2019
I solved the problem changing the region extyension with the following
rule:
g.region n=n+0.5 s=s+0.5 w=w+0.5 e=e+0.5
where 0.5 is half the resolution. But I do not understand why the command
create the nodata within the dem without extending region.
R
Il giorno mer 17 lug 2019 alle ore 13:16 Roberto Marzocchi <
roberto.marzocchi a gmail.com> ha scritto:
> I use r.in.xyz.
>  It import correctly the data but create strange nodata value which are
> not present in the input XYZ text file.
> Attached two screenshots of the output result
> R
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190717/cea60a88/attachment.html>
