[GRASS-dev] [GRASS GIS] #3873: winGRASS Version: 7.7.dev - deprecated warning in 3D modus
GRASS GIS trac at osgeo.org
Mon Jul 22 06:39:49 PDT 2019
 Reporter:  hellik                  |      Owner:  grass-dev@…
     Type:  defect                  |     Status:  new
 Priority:  normal                  |  Milestone:  7.8.0
Component:  wxGUI                   |    Version:  svn-trunk
 Keywords:  python3, py3, wingrass  |        CPU:  All
 Platform:  MSWindows               |
 tested with
 System Info
 Code revision: 2929fffa9
 Build date: 2019-07-21
 Build platform: x86_64-w64-mingw32
 GDAL: 2.4.1
 PROJ.4: 5.2.0
 GEOS: 3.7.2
 SQLite: 3.26.0
 Python: 3.7.0
 wxPython: 4.0.3
 Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
 add NC elevation sample data set, then switch to 3D modus in map display
 C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\nviz\tools.py:58
 08: wxPyDeprecationWarning: Call to deprecated item. Use
 SetToolTip instead.
   _("Adjusts the distance and direction of the image
 viewpoint"))
 C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\nviz\tools.py:30
 90: wxPyDeprecationWarning: Call to deprecated item. Use
 SetToolTip instead.
   text.SetToolTipString(tooltip)
 C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\nviz\tools.py:93
 SetToolTip instead.
   color.SetToolTipString(_("Change wire color"))
 43: wxPyDeprecationWarning: Call to deprecated item. Use
 SetToolTip instead.
   self.SetToolTipString(_("Adjusts the light direction. "
 C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\nviz\tools.py:55
 9: wxPyDeprecationWarning: Call to deprecated item. Use
 SetToolTip instead.
   _("Frames are recorded with given frequency (FPS). "))
 Lade Rasterkarte <elevation at PERMANENT>...
 Übersetze Farben der Rasterkarte <elevation at PERMANENT>...
 C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\nviz\tools.py:52
 18: wxPyDeprecationWarning: Call to deprecated item. Use
 GetSize instead
   width = help.GetGrandParent().GetSizeTuple()[0]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3873>
