[GRASS-dev] [GRASS GIS] #3455: Grass 7.2.1 returns "Extension(...)not found" when installing addon
trac at osgeo.org
Tue Jul 23 03:25:56 PDT 2019
Reporter: bcbernardo | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.4
Component: Addons | Version: 7.4.0
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows
Changes (by vinhussey):
* status: closed => reopened
* cc: vinhussey (added)
* component: Default => Addons
* platform: MSWindows 7 => MSWindows
* version: 7.2.1 => 7.4.0
* resolution: worksforme =>
Comment:
The windows repository seems to be hardcoded to
http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/ (in grass
7.4 at least).
The files are actually located at
http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/
C:\>g.extension
url="http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/"
--verbose extension=v.tin.to.rast
Downloading precompiled GRASS Addons <v.tin.to.rast>...
Downloading source code for <v.tin.to.rast> from
<http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/v.tin.to.rast.zip>
which is identified as 'remote_zip' type of source...
ERROR: Extension <v.tin.to.rast> not found
As shown above, the url parameter does not appear to work (unless I am not
using it correctly).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:5>
