[GRASS-dev] [GRASS GIS] #3875: GRASS doesn't start with non-system locale
trac at osgeo.org
Sat Jul 27 08:45:17 PDT 2019
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.6.2
Component: Default | Version: svn-trunk
Resolution: | Keywords: init script
CPU: Unspecified | Platform: All
Comment (by hellik):
windows 10 box with german locale, switching winGRASS to english, wxGUI
starts, though some warning:
Error: Reading settings from file
<C:\Users\myuser\AppData\Roaming\GRASS7\wx> failed.
Details: not enough values to unpack (expected 2, got 1)
Line: ''
switching to ru, wxGUI starts and the GUI is partly in russian, though the
same warning:
Line: ''
tested with
System Info
GRASS version: 7.7.dev
Code revision: 5249e44ac
Build date: 2019-07-24
Build platform: x86_64-w64-mingw32
GDAL: 2.4.1
PROJ.4: 5.2.0
GEOS: 3.7.2
SQLite: 3.26.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:2>
