[GRASS-dev] [GRASS GIS] #3455: Grass 7.2.1 returns "Extension(...)not found" when installing addon
GRASS GIS trac at osgeo.org
Sat Jul 27 11:51:42 PDT 2019
  Reporter:  bcbernardo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:  7.2.4
 Component:  Addons       |    Version:  7.4.0
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MSWindows
Comment (by hellik):
 Replying to [comment:5 vinhussey]:
 > The windows repository seems to be hardcoded to
 http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/ (in grass
 7.4 at least).
 > The files are actually located at
 http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/
 >     C:\>g.extension
 url="http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/"
 >     --verbose extension=v.tin.to.rast
 >     Downloading precompiled GRASS Addons <v.tin.to.rast>...
 >     Downloading source code for <v.tin.to.rast> from
 <http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/v.tin.to.rast.zip>
 >     which is identified as 'remote_zip' type of source...
 >     ERROR: Extension <v.tin.to.rast> not found
 > As shown above, the url parameter does not appear to work (unless I am
 not using it correctly).
 the subject of the trac ticket is about **Grass 7.2.1v.** in windows.
 winGRASS versions:
 * GRASS GIS 7.4.4 (old stable)
 * GRASS GIS 7.6.1 (new stable)
 which winGRASS version are you refering to while reopening the ticket?
 ​http://wingrass.fsv.cvut.cz/grass74
 >/x86_64/addons/grass-7.4.4/ (in grass 7.4 at least).
 precompiled addon python scripts may work between different winGRASS
 releases; though it's very unlikely that C addons are working due to
 different GRASS library version.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:7>
