[GRASS-dev] [GRASS GIS] #3882: winGRASS Version: 7.7.dev - not able to digitize vector polygons
trac at osgeo.org
Wed Jul 31 08:29:17 PDT 2019
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.8.0
Component: wxGUI | Version: svn-trunk
Keywords: python3, py3, wingrass | CPU: x86-64
Platform: MSWindows |
tested with
System Info
GRASS version: 7.7.dev
Code revision: 5249e44ac
Build date: 2019-07-24
Build platform: x86_64-w64-mingw32
GDAL: 2.4.1
PROJ.4: 5.2.0
GEOS: 3.7.2
SQLite: 3.26.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
steps done in NC sample data set
* add elevatin as background raster
* map display -> vector digitizer
* new vector, add some additional columns in attribute table
* choosing the button ''digitize new area''
* a message pops up that no appropriate tool is choosen (screenshot will
be added)
* you have to press the button ''digitize new point'' or ''digitize new
line'', then press the button ''digitize new area''
* digitizing the area's boundary, try to close the area, but only the
boundary is digitized, no area is generated
* doing the same in winGRASS7.6.1, closing the boundary generates a new
area
a lot of warnings and errors are in the console:
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\gth
read.py", line 121, in OnDone
event.ondone(event)
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\ren
der.py", line 469, in OnRenderDone
self.updateProgress.emit(layer=self.layer)
File "C:\OSGEO4~1\apps\grass\grass77\etc\python\grass\pydi
spatch\signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
spatch\dispatcher.py", line 349, in send
**named
spatch\robustapply.py", line 60, in robustApply
return receiver(*arguments, **named)
der.py", line 743, in ReportProgress
self.renderDone.emit()
**named
der.py", line 650, in OnRenderDone
raise GException(_("Rendering failed: %s" % msg))
core.gcmd
GException
Rendering failed: Expecting 807x466 image but got 807x501
image.
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\vdigit\t
oolbars.py", line 856, in OnSelectMap
self.StartEditing(self.layers[selection])
oolbars.py", line 922, in StartEditing
self.EnableAll()
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\gui_core
\toolbars.py", line 223, in EnableAll
for item in self._toolbarData():
oolbars.py", line 268, in _toolbarData
return self._getToolbarData(data)
\toolbars.py", line 233, in _getToolbarData
retData.append(self._defineTool(*args))
\toolbars.py", line 241, in _defineTool
return (name, icon.GetBitmap(),
File
"C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\icons\icon.py",
line 100, in GetBitmap
bmp = wx.Bitmap(name=self.imagepath)
wx._core
wxAssertionError
C++ assertion "wxString::Format("%.3f", 1.23).find(str) !=
wxString::npos" failed at ..\..\src\common\intl.cpp(1648) in
wxLocale::GetInfo(): Decimal separator mismatch -- did you
use setlocale()?If so, use wxLocale to change the locale
instead.
oolbars.py", line 391, in OnAddAreaTool
self.OnAddArea(event)
oolbars.py", line 369, in OnAddArea
self.addArea, self.icons['addArea'].GetBitmap())
File
wx._core
wxAssertionError
instead.
File
wx._core
wxAssertionError
instead.
Editing of vector map <mytest4 at user1> successfully finished
Building topology for vector map <mytest4 at user1>...
Registering primitives...
Building areas...
Attaching islands...
Attaching centroids...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3882>
