[GRASS-dev] instructions to update my local copy of trunk
Vaclav Petras wenzeslaus at gmail.com
Sun Jun 2 13:20:17 PDT 2019
On Sun, Jun 2, 2019 at 4:11 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi Vaclav,
> El dom., 2 jun. 2019 a las 21:52, Vaclav Petras (<wenzeslaus at gmail.com>)
> escribió:
>> On Sun, Jun 2, 2019 at 3:00 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hi devs
>>> Following instructions here:
>>> https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate,
>>> I get:
>>> [veroandreo at localhost grass7_trunk]$ git remote -v
>>> origin git at github.com:veroandreo/grass.git (fetch)
>>> origin git at github.com:veroandreo/grass.git (push)
>>> upstream git at github.com:OSGeo/grass.git (fetch)
>>> upstream git at github.com:OSGeo/grass.git (push)
>>> [veroandreo at localhost grass7_trunk]$ git fetch upstream
>>> remote: Enumerating objects: 242, done.
>>> remote: Counting objects: 100% (242/242), done.
>>> remote: Compressing objects: 100% (25/25), done.
>>> remote: Total 296 (delta 223), reused 233 (delta 217), pack-reused 54
>>> Receiving objects: 100% (296/296), 56.83 KiB | 1.18 MiB/s, done.
>>> Resolving deltas: 100% (226/226), completed with 105 local objects.
>>> From github.com:OSGeo/grass
>>>  * [new branch]          changelog_fix_msg -> upstream/changelog_fix_msg
>>>    3797ccaaf..b300e66fc  master            -> upstream/master
>>>    1ca5e4e34..e1e13d782  releasebranch_7_4 -> upstream/releasebranch_7_4
>>>    15f53e803..dcfce280b  releasebranch_7_6 -> upstream/releasebranch_7_6
>>> [veroandreo at localhost grass7_trunk]$ git branch -a
>>> * master
>>>   remotes/origin/master
>>>   remotes/origin/releasebranch_7_0
>>>   remotes/origin/releasebranch_7_2
>>>   remotes/origin/releasebranch_7_4
>>>   remotes/origin/releasebranch_7_6
>>>   remotes/upstream/changelog_fix_msg
>>>   remotes/upstream/master
>>>   remotes/upstream/releasebranch_7_0
>>>   remotes/upstream/releasebranch_7_2
>>>   remotes/upstream/releasebranch_7_4
>>>   remotes/upstream/releasebranch_7_6
>>> [veroandreo at localhost grass7_trunk]$ git rebase upstream/master
>>> First, rewinding head to replay your work on top of it...
>>> Fast-forwarded master to upstream/master.
>>> [veroandreo at localhost grass7_trunk]$ git status
>>> On branch master
>>> Your branch is ahead of 'origin/master' by 51 commits.
>>>   (use "git push" to publish your local commits)
>>> Why does my origin/master is now ahead by 51 commits, if I have not a
>>> single local change? I just want to get the new stuff from upstream and
>>> update my fork and local copy of the source code (what I used to do with
>>> `svn update`).
>> Your branch 'master' is ahead of 'origin/master'. You need to push to
>> origin (something like `git push origin` but I think little different, Git
>> will tell you).
> but I haven't made a single change... that's what I don't get. How can I
> be ahead?
Your local master branch is now in sync with upstream/master, but the
commits from upstream/master are not in your origin/master (which is in
GitHub fork), hence your master is ahead.
> BTW, you can compare what you seen on GitHub with what you see locally,
>> e.g.
>> git log --graph --abbrev-commit --pretty=oneline  --max-count=10
> what am I supposed to see there? If I change to 50, i see:
If you look at your fork's master at GitHub, these won't be there.
(Assuming I got what is going on here.)
> [veroandreo at localhost grass7_trunk]$ git log --graph --abbrev-commit
> --pretty=oneline  --max-count=50
> * f01aa67cf* (HEAD -> master) *i18N: sync from Transifex
> * 9d983ac94 Py2/Py3 compat: Use "gettext.install(..., unicode=True)" in
> Python 2.
> * 65a5a96a6 PyGRASS GridModule silently ignores when module has no output
> defined, see https://trac.osgeo.org/grass/ticket/3852 (#21)
> * e4835d475 v.db.addtable
> * 3053328ae v.db.connect
> * 85f000ebf r.stream.extract
> * e5cfb9488 Python2 fixes
> * e3ed0b7df super Python2 valide
> * 196428874 added .github/FUNDING.yml
> * 74f55730a r.out.mpeg fails because the output file name is empty
> * e3418cbad change attribute/method argument name
> * da230fe59 fixes
> * 9a968d59e Draft intro added
> * 6d0b0ded2 r.in.wms: add proxy for GDAL driver
> * 94754df99 libinit: shorten GRASS prompt
> * de48a8d77 r.cost/r.walk: check return code
> * e9070421b libproj: fix support for PROJ6
> * 29297bc2e segmentlib: malloc -> calloc
> * efee46fc5 v.in.ogr: fix OGR extents
> * 107e3a616 Travis-CI: enable ccache for faster builds
> * f1d7d2394 svn2cl replaced with tools/gitlog2changelog.py
> * e240b5a60 tools/gitlog2changelog.py: added
> * 8036fa977 contributors.csv: email updated
> * 67a759c39 translators.csv: email update (test for grass-commit ML
> notification)
> * 99cae4154 wxGUI/digitizer: fixes for python 3 (
> https://trac.osgeo.org/grass/ticket/3777)
> * bf06fae1d lib/init/grass.py: Stop clearing the terminal
> * 34e35a977 wxGUI About System: 'GRASS SVN revision' changed to more
> generic 'Code revision'
> * 2b570a9a0 GRASS_VERSION_SVN -> GRASS_VERSION_GIT + update g.version
> * 97a123681 update readme section - get write access
> * 80072cf87 readme: Convert to markdown and add travis badge
> * ccb7b6b28 r.contour: fix broken contour lines (#3846), clean contour
> lines tracing back on themselves
> * c757924cc pygrass.gis: Make Region importable from grass.pygrass.gis
> * 7f1dd0d9f pythonlib: fix encoding
> * 9d4306801 fix tests for Python 3
> * 8b9512b8b *(origin/master)* pygrass: fixing doctests (only for Python 3)
> * ebe8eb958 pygrass: fixes for Python 3
> * 4f2c2421e gunittest: when printing, it should be 'str' in py 2 and 3
> * b29dda7dd t.rast.gapfill: fix tests
> * b113de305 t.rast.univar: fix tests
> * ec44b8432 pygrass: decode only if stdout/stderr not empty
> Note the boldface. What does it mean?
> I'm completely lost...
> Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190602/b876b4c6/attachment.html>
