[GRASS-dev] instructions to update my local copy of trunk
Markus Metz
markus.metz.giswork at gmail.com
Sun Jun 2 13:23:24 PDT 2019
On Sun, Jun 2, 2019 at 8:59 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi devs
> Following instructions here:
https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate,
I get:
> [veroandreo at localhost grass7_trunk]$ git remote -v
> origin git at github.com:veroandreo/grass.git (fetch)
> origin git at github.com:veroandreo/grass.git (push)
> upstream git at github.com:OSGeo/grass.git (fetch)
> upstream git at github.com:OSGeo/grass.git (push)
> [veroandreo at localhost grass7_trunk]$ git fetch upstream
> remote: Enumerating objects: 242, done.
> remote: Counting objects: 100% (242/242), done.
> remote: Compressing objects: 100% (25/25), done.
> remote: Total 296 (delta 223), reused 233 (delta 217), pack-reused 54
> Receiving objects: 100% (296/296), 56.83 KiB | 1.18 MiB/s, done.
> Resolving deltas: 100% (226/226), completed with 105 local objects.
> From github.com:OSGeo/grass
> * [new branch] changelog_fix_msg -> upstream/changelog_fix_msg
> 3797ccaaf..b300e66fc master -> upstream/master
> 1ca5e4e34..e1e13d782 releasebranch_7_4 -> upstream/releasebranch_7_4
> 15f53e803..dcfce280b releasebranch_7_6 -> upstream/releasebranch_7_6
> [veroandreo at localhost grass7_trunk]$ git branch -a
> * master
> remotes/origin/master
> remotes/origin/releasebranch_7_0
> remotes/origin/releasebranch_7_2
> remotes/origin/releasebranch_7_4
> remotes/origin/releasebranch_7_6
> remotes/upstream/changelog_fix_msg
> remotes/upstream/master
> remotes/upstream/releasebranch_7_0
> remotes/upstream/releasebranch_7_2
> remotes/upstream/releasebranch_7_4
> remotes/upstream/releasebranch_7_6
> [veroandreo at localhost grass7_trunk]$ git rebase upstream/master
> First, rewinding head to replay your work on top of it...
> Fast-forwarded master to upstream/master.
> [veroandreo at localhost grass7_trunk]$ git status
> On branch master
> Your branch is ahead of 'origin/master' by 51 commits.
> (use "git push" to publish your local commits)
> Why does my origin/master is now ahead by 51 commits, if I have not a
single local change?
Read carefully: "Your branch is ahead of 'origin/master' by 51 commits."
That means your local branch master is ahead of your fork at github:
"origin git at github.com:veroandreo/grass.git"
Your local branch master is based on "upstream git at github.com:OSGeo/grass.git",
i.e. the original repo.
You need to update your fork with something like
git push origin
Don't know if that helps,
Markus M
> I just want to get the new stuff from upstream and update my fork and
local copy of the source code (what I used to do with `svn update`).
> Can someone please provide full instructions [ideally in
https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate]?
> Thanks much in advance
> Vero
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190602/48da9899/attachment-0001.html>
