[GRASS-dev] instructions to update my local copy of trunk
Vaclav Petras
wenzeslaus at gmail.com
Sun Jun 2 20:16:46 PDT 2019
On Sun, Jun 2, 2019 at 9:01 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Ok, got it... the `git push origin` put my origin in sync with upstream.
> So, for the way we have set remote/origin and remote/upstream, the update
> goes from upstream to local and from local to origin, is that right?
Right.
> Is there another way? I would have imagined, dunno why, that the update
> would go from upstream to origin to local...
That would have to happen on GitHub. For whatever reason GitHub does not
help you to do this automatically (I guess for case when one wants to use
different workflow...).
> In any case to update my local copy and recompile the source code, I could
> ommit the git push origin for now, though I'll need it eventually if I make
> local changes myself.
If you are creating a new branch locally, you want your local master up to
date, if on GitHub, you need also your origin/master up to date.
> El dom., 2 jun. 2019 a las 22:23, Markus Metz (<
> markus.metz.giswork at gmail.com>) escribió:
>> On Sun, Jun 2, 2019 at 8:59 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > Hi devs
>> > Following instructions here:
>> https://trac.osgeo.org/grass/wiki/HowToGit#Keepyourlocalsourcecodeuptodate,
>> I get:
>> > [veroandreo at localhost grass7_trunk]$ git remote -v
>> > origin git at github.com:veroandreo/grass.git (fetch)
>> > origin git at github.com:veroandreo/grass.git (push)
>> > upstream git at github.com:OSGeo/grass.git (fetch)
>> > upstream git at github.com:OSGeo/grass.git (push)
>> > [veroandreo at localhost grass7_trunk]$ git fetch upstream
>> > remote: Enumerating objects: 242, done.
>> > remote: Counting objects: 100% (242/242), done.
>> > remote: Compressing objects: 100% (25/25), done.
>> > remote: Total 296 (delta 223), reused 233 (delta 217), pack-reused 54
>> > Receiving objects: 100% (296/296), 56.83 KiB | 1.18 MiB/s, done.
>> > Resolving deltas: 100% (226/226), completed with 105 local objects.
>> > From github.com:OSGeo/grass
>> > * [new branch] changelog_fix_msg -> upstream/changelog_fix_msg
>> > 3797ccaaf..b300e66fc master -> upstream/master
>> > 1ca5e4e34..e1e13d782 releasebranch_7_4 -> upstream/releasebranch_7_4
>> > 15f53e803..dcfce280b releasebranch_7_6 -> upstream/releasebranch_7_6
>> > [veroandreo at localhost grass7_trunk]$ git branch -a
>> > * master
>> > remotes/origin/master
>> > remotes/origin/releasebranch_7_0
>> > remotes/origin/releasebranch_7_2
>> > remotes/origin/releasebranch_7_4
>> > remotes/origin/releasebranch_7_6
>> > remotes/upstream/changelog_fix_msg
>> > remotes/upstream/master
>> > remotes/upstream/releasebranch_7_0
>> > remotes/upstream/releasebranch_7_2
>> > remotes/upstream/releasebranch_7_4
>> > remotes/upstream/releasebranch_7_6
>> > [veroandreo at localhost grass7_trunk]$ git rebase upstream/master
>> > First, rewinding head to replay your work on top of it...
>> > Fast-forwarded master to upstream/master.
>> > [veroandreo at localhost grass7_trunk]$ git status
>> > On branch master
>> > Your branch is ahead of 'origin/master' by 51 commits.
>> > (use "git push" to publish your local commits)
>> > Why does my origin/master is now ahead by 51 commits, if I have not a
>> single local change?
>> Read carefully: "Your branch is ahead of 'origin/master' by 51 commits."
>> That means your local branch master is ahead of your fork at github:
>> "origin git at github.com:veroandreo/grass.git"
>> Your local branch master is based on "upstream git at github.com:OSGeo/grass.git",
>> i.e. the original repo.
>> You need to update your fork with something like
>> git push origin
>> Don't know if that helps,
>> Markus M
>> > I just want to get the new stuff from upstream and update my fork and
>> local copy of the source code (what I used to do with `svn update`).
>> > Can someone please provide full instructions [ideally in
>> > Thanks much in advance
>> > Vero
>> > _______________________________________________
>> > grass-dev mailing list
>> > grass-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190602/3aaea1a1/attachment-0001.html>
