[GRASS-dev] [GRASS GIS] #3832: Add environment variable to create all temp-files at a user-defined location (outside the mapsets)
trac at osgeo.org
Mon Jun 3 07:50:55 PDT 2019
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: environment variables
CPU: Unspecified | Platform: All
Comment (by martinl):
Such variable is currently implemented only for vector library
(GRASS_VECTOR_TMPDIR_MAPSET), see also related discussion,
https://lists.osgeo.org/pipermail/grass-dev/2015-June/075220.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3832#comment:3>
