[GRASS-dev] error in v.overlay: Unable to write spatial index. Wrong node position
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 10 09:12:17 PDT 2019
I just came across this error:
ERROR: Unable to write spatial index. Wrong node position (950329504) in
file (should be 950333637).
ERROR: Clipping steps failed. Check above error messages and see following
details:
Module run None ['v.overlay', 'binput=temp_30311', 'operator=and',
'olayer=0,1,0', 'ainput=sq_batiments',
'output=walous_temp_batiment_tile_18980'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Any hint of what this might mean ? Should I file a bug report ?
Moritz
