[GRASS-dev] [GRASS GIS] #3860: GRASS GIS producing different slope than GDAL
GRASS GIS trac at osgeo.org
Mon Jun 10 13:30:23 PDT 2019
  Reporter:  mazingaro  |      Owner:  grass-dev@…
      Type:  defect     |     Status:  reopened
  Priority:  normal     |  Milestone:  7.6.2
 Component:  Raster     |    Version:  unspecified
Resolution:             |   Keywords:  slope
       CPU:  x86-64     |   Platform:  Linux
Comment (by mmetz):
 Replying to [comment:9 mankoff]:
 > I think the issue is related to the region.
 > The `r.slope.aspect` documentation in the NOTES section implies that the
 region is adjusted to the raster. I do not find that to be the case.
 Specifically in the NC test data, I've created the following slope
 rasters, and then looked at their univariate statistics:
 > g.region raster=elevation
 > r.slope.aspect elevation=elevation slope=slope_0
 > r.slope.aspect -a elevation=elevation slope=slope_1
 > g.region res=30 -pa
 > r.slope.aspect elevation=elevation slope=slope_2
 > r.slope.aspect -a elevation=elevation slope=slope_3
 > for i in $(seq 0 3); do
 >   (echo -n "slope_${i} "; r.univar slope_${i} | grep range) | tr '\n' '
 > done
 Please also check the extents and resolution of slope_0, slope_1, slope_2,
 slope_3. You need to set the region to the raster map before running
 r.univar because r.univar uses the current region. Therefore these results
 are not what you intend to get because they are all obtained with the same
 region settings:
 > Results are:
 > slope_0 range: 36.3347
 > slope_1 range: 36.3347
 > slope_2 range: 13.7754
 > slope_3 range: 25.3968
 Alternatively, try `r.info -s` which ignores the current region and
 reports simple raster stats stored in metadata.
 Replying to [comment:12 neteler]:
 the region is adjusted to the raster. I do not find that to be the case.
 > Reopening for manual to be corrected (if that's the solution to the
 reported differences).
 I think the manual is correct.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3860#comment:13>
