[GRASS-dev] error in v.overlay: Unable to write spatial index. Wrong node position
Moritz Lennert
mlennert at club.worldonline.be
Tue Jun 11 02:12:27 PDT 2019
On 10/06/19 21:39, Markus Metz wrote:
> On Mon, Jun 10, 2019 at 6:12 PM Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> > Hi,
> > I just came across this error:
> > ERROR: Unable to write spatial index. Wrong node position (950329504) in
> > file (should be 950333637).
> > ERROR: Clipping steps failed. Check above error messages and see
> following
> > details:
> > Module run None ['v.overlay', 'binput=temp_30311',
> 'operator=and',
> > 'olayer=0,1,0', 'ainput=sq_batiments',
> > 'output=walous_temp_batiment_tile_18980'] ended with error
> > Process ended with non-zero return code 1. See errors in the
> (error)
> > output.
> > Any hint of what this might mean ? Should I file a bug report ?
> That means there was an error while writing out a spatial index, the
> file size of the file holding the partially written out spatial index is
> smaller than expected. Is this error reproducible on a different
> partition/file system? Can you provide test data to reproduce?
This was running on one node in an HPC. Up to now I haven't been able to
reproduce it, so it was probably some glitch on that node. If I have
other occurences, I'll try to narrow it down and provide test data.
Moritz
