[GRASS-dev] [GRASS-user] GRASS python + PyCharm
Vaclav Petras
wenzeslaus at gmail.com
Wed Jun 12 20:21:03 PDT 2019
On Wed, Jun 12, 2019 at 5:09 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Jun 12, 2019 at 10:49 AM Helmut Kudrnovsky <hellik at web.de> wrote:
> > Hi,
> > PyCharm is a nice python IDE.
> > anyone some experiences to share how to integrate GRASS python (pygrass
> and
> > grass script) into the PyCharm IDE environment?
> Please add your notes also here then:
> https://grasswiki.osgeo.org/wiki/Tools_for_Python_programming#PyCharm_IDE
Or, if PyCharm allows you to supply custom executable and parameters script
execution, you can try to set it up with `grass ... --exec`. The drawback
is that debugger may not support that.
Alternatively, as a combination of both, you can set up a shortcut for
"PyCharm with GRASS GIS" using `grass --tmp-location XY --exec pycharm`. In
that case, as in case with running it inside, some Python version/packages
issues may arise more likely.
Best,
Vaclav
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190612/31810696/attachment.html>
