[GRASS-dev] [GRASS GIS] #3768: g.remove and i.group
trac at osgeo.org
Mon Mar 4 05:32:04 PST 2019
Reporter: SteGobbi | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: unspecified
Keywords: | CPU: Unspecified
Platform: All |
Hello again.
I have noticed that the g.remove command correctly removes all the raster
files from the location folders, but it doesn't delete the name of the
removed file from the ref list, if the map is in any group list.
It could lead to errors in the execution of operation where the parameter
"group" has to be set, for instance with 'i.ortho.photo' or 'i.maxlik' and
so on.
I was wondering if could be possible to add a line in the command g.remove
to remove the name of the input map from the ref file of its group.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3768>
