[GRASS-dev] [GRASS GIS] #3770: [testsuite] The testsuite requires Location: "other_location"
GRASS GIS trac at osgeo.org
Mon Mar 4 13:26:14 PST 2019
 Reporter:  pmav99       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Tests        |    Version:  svn-trunk
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 The testsuite requires Location: "other_location" which does not exist and
 does not get downloaded by the bootstrapping code. The relevant lines on
 {{{testsuite/examples/test_framework_GRASS_GIS_with_NC.sh}}} are:
 # run tests for the current source code
 cd $REPORTS/$CURRENT_REPORTS_DIR
 $PYTHON $GRASS_MULTI_RUNNER \
     --grassbin $GRASSBIN \
     --grasssrc $GRASSSRC \
     --grassdata $GRASSDATA \
     --location nc_spm_08_grass7 --location-type nc \
     --location other_location --location-type other_type
 If this is a well known location, then the bootstrapping code should
 download it as well. If it is not, the it should probably be removed.
 Updating the instructions at {{{
 lib/python/docs/src/gunittest_running_tests.rst }}} would be nice too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3770>
