[GRASS-dev] [GRASS GIS] #3487: vector digitizer unstable
trac at osgeo.org
Tue Mar 5 08:41:07 PST 2019
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.6.1
Component: wxGUI | Version: 7.2.2
Resolution: | Keywords: digitizer, ctypes
CPU: OSX/Intel | Platform: MacOSX
Comment (by balagates):
I attached a file with console output with DEBUG=5 and WX_DEBUG=5 during
crash using the downloaded version 7.6.0 on macOS 10.12.6. Maybe the
"RenderMapMgr.Abort()" should be investigated?
I also see a likely bug when changing the Map Display mode to Vector
digitizer. I believe the message "Expecting 825x586 image but got 825x622
image." is caused by the vector digitizer controls being added but the map
size not being adjusted. I do not think this is causing the crash. After
changing the mode you can resize the window to eliminate that error.
Another clue might be that after a crash the topology for the vector is
messed up and needs to be rebuilt. That might only mean it got far enough
to open the vector for editing but did not close it properly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3487#comment:19>
