[GRASS-dev] SVN hint: less disk consumption after "svn cleanup"
Markus Metz markus.metz.giswork at gmail.com
Tue Mar 5 12:26:47 PST 2019
On Tue, Mar 5, 2019 at 1:11 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> esp. for those who are contributing to GRASS GIS for while and have
> .svn/ directory/-ies in their local source code copy, here a hint to
> save (notably) disk space:
> running "svn cleanup" shrinks the respective svn control files.
> Here a one-liner, to be run in the parent directory of where your
> (GRASS GIS) svn based source code is:
> # loop over all directories which contain a ./svn/ directory:
> for i in $(ls */.svn/wc.db | cut -d'/' -f1) ; do (cd $i ; svn cleanup) ;
done
nice!
> In my case, with 15 different GRASS source code directories (different
> version, dev and relbranches), it saved me 11 GB (!). Neat :-)
you will need that disk space when GRASS moves to git which needs more disk
space than svn
Markus M
> cheers,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190305/908dcb3b/attachment.html>
