[GRASS-dev] [GRASS GIS] #3774: lib/gis/testsuite/test_parser_json.py are failing
trac at osgeo.org
Wed Mar 6 01:27:06 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
@neteler yes, I am sorry, I should have elaborated a bit more.
That was the output of the tests that show the differences between
expected and actual output. The lines that throw the errors are 46 and 74.
I don't feel comfortable suggesting a fix here, because I am not familiar
enough with fully qualified map names and their nuances. In other words I
can't really judge if the error is in the test itself or in the tested
code. But the test is failing and needs to be fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3774#comment:3>
