[GRASS-dev] [GRASS GIS] #3783: Python 3: ./raster/r.patch/testsuite/test_rpatch_artificial.py is broken
trac at osgeo.org
Wed Mar 6 23:42:28 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Description changed by pmav99:
Old description:
> This is the traceback:
> ERROR: test_patching_cell (__main__.TestSmallDataNoOverlap)
> Test patching two neighboring CELL raster maps
> Traceback (most recent call last):
> File "raster/r.patch/testsuite/test_rpatch_artificial.py", line 162, in
> test_patching_cell
> self.cell_patched_ref, precision=0)
> File "etc/python/grass/gunittest/case.py", line 767, in
> assertRastersNoDifference
> 'assertRastersNoDifference')
> File "etc/python/grass/gunittest/case.py", line 681, in
> _compute_difference_raster
> s=second))
> File "etc/python/grass/gunittest/gmodules.py", line 128, in call_module
> output, errors = process.communicate(input=stdin)
> File "/usr/lib/python3.7/subprocess.py", line 939, in communicate
> stdout, stderr = self._communicate(input, endtime, timeout)
> File "/usr/lib/python3.7/subprocess.py", line 1666, in _communicate
> input_view = memoryview(self._input)
> TypeError: memoryview: a bytes-like object is required, not 'str'
> This is the the suggested fix (git diff):
> diff --git a/lib/python/gunittest/case.py b/lib/python/gunittest/case.py
> index cf995e4b2..d94a72b69 100644
> --- a/lib/python/gunittest/case.py
> +++ b/lib/python/gunittest/case.py
> @@ -675,10 +675,12 @@ class TestCase(unittest.TestCase):
> diff = self._get_unique_name('compute_difference_raster_' +
> name_part
> + '_' + first + '_minus_' + second)
> - call_module('r.mapcalc',
> - stdin='"{d}" = "{f}" - "{s}"'.format(d=diff,
> - f=first,
> - s=second))
> + expression = '"{d}" = "{f}" - "{s}"'.format(
> + d=diff,
> + f=first,
> + s=second
> + call_module('r.mapcalc', stdin=expression.encode("utf-8"))
> return diff
> # TODO: name of map generation is repeted three times
> Works on both Python 2 and Python 3
New description:
test_patching_cell
s=second))
name_part
- f=first,
- s=second))
+ expression = '"{diff}" = "{first}" - "{second}"'.format(
+ diff=diff,
+ first=first,
+ second=second
return diff
Ticket URL: <https://trac.osgeo.org/grass/ticket/3783#comment:1>
