[GRASS-dev] another grass python library question
Michael Barton Michael.Barton at asu.edu
Thu Mar 7 05:03:29 PST 2019
Here is another issue with an infurating problem of parameter pairs.
I have input map names saved to a set of variables.
I want to do the following:
grass.run_command('g.copy ', raster=[variable],[mapname])
The output [mapname] can be a string for a mapname or a previously defined variable containing the mapname.
I've looked at the docs for the scripting and python libraries and nothing there helps. I consistently get a file not found error or  a syntax error if I try to use string substitution.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190307/b2470d28/attachment.html>
