[GRASS-dev] [GRASS GIS] #2048: i.pansharpen limited to 8-bit imagery
GRASS GIS trac at osgeo.org
Fri Mar 8 03:34:12 PST 2019
  Reporter:  Nikos       |      Owner:  grass-dev@…
  Alexandris             |
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.6.1
 Component:  Imagery     |    Version:  svn-trunk
Resolution:              |   Keywords:  i.pansharpen, sharpening, fusion,
                         |  brovey, ihs, pca, 8-bit
       CPU:  All         |   Platform:  Unspecified
Comment (by cmbarton):
 Also, if you try to go beyond the range limit in the GUI, the value will
 be reset to the minimum (if you try to go below) or the maximum (if you
 try to go above. No error message is generated because the values are
 automatically corrected back to the limited range. In the terminal, you do
 get an error if you try to go outside the range.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2048#comment:39>
