[GRASS-dev] [PROJ] GRASS GIS + PROJ 6 + GDAL 2.5
Even Rouault even.rouault at spatialys.com
Fri Mar 8 03:41:27 PST 2019
On vendredi 8 mars 2019 12:27:37 CET Markus Metz wrote:
> On Fri, Mar 8, 2019 at 10:49 AM Roger Bivand <Roger.Bivand at nhh.no> wrote:
> > Since rgdal::make_EPSG() is facing the same problems of listing tabulated
> > EPSG fields as g.proj -l, I was very happy to see Markus' code in
> > g.proj/main.c mentioned in this thread, and have used this approach in
> https://r-forge.r-project.org/scm/viewvc.php/pkg/src/proj_info6.cpp?view=mar
> kup&root=rgdal
> > However, there are plenty of messages such as: "proj_as_proj_string:
> > Unsupported conversion method: Lambert Conic Conformal (West
> Orientated)". I
> > haven't installed GRASS trunk with PROJ6, so I can't see whether g.proj -l
> > also sees the same messages.
> I get the same messages with g.proj, but no error code from PROJ error
> handlers.
> > If it does, maybe we could ask on the proj list
> yes, we should ask. For now g.proj is ignoring those codes for which no
> proj string can be retrieved.
I'm not sure what the question is exactly :-) Is that proj_context_errno()
doesn't return an error in that case ?
That's related to the error being emitted from the new code emitting C++
exceptions, which are caught by the C wrapper. It doesn't set errno style
errors currently. I'm not a big fan of the errno approach, and find the proper
error string currently emitted to be more expressive, but that can be
discussed if some harmonization should be done.
Even
http://www.spatialys.com
