[GRASS-dev] [GRASS GIS] #3787: pkg-config references unknown shared library
GRASS GIS trac at osgeo.org
Sat Mar 9 10:50:41 PST 2019
 Reporter:  Bas Couwenberg  |      Owner:  grass-dev@…
     Type:  defect          |     Status:  new
 Priority:  normal          |  Milestone:  7.6.1
Component:  Default         |    Version:  svn-releasebranch76
 Keywords:                  |        CPU:  Unspecified
 Platform:  Linux           |
 The lintian QA tool reported several pkg-config-references-unknown-shared-
 library issues:
  * usr/share/pkgconfig/grass.pc -lgrass_gmath
  * usr/share/pkgconfig/grass.pc -lgrass_gis
  * usr/share/pkgconfig/grass.pc -lgrass_datetime
  * usr/share/pkgconfig/grass.pc -lgrass_gproj
  * usr/share/pkgconfig/grass.pc -lgrass_raster
  * usr/share/pkgconfig/grass.pc -lgrass_vector
  * usr/share/pkgconfig/grass.pc -lgrass_dbmibase
  * usr/share/pkgconfig/grass.pc -lgrass_dbmiclient
  * usr/share/pkgconfig/grass.pc -lz
  * usr/share/pkgconfig/grass76.pc -lgrass_gmath
  * usr/share/pkgconfig/grass76.pc -lgrass_gis
  * usr/share/pkgconfig/grass76.pc -lgrass_datetime
  * usr/share/pkgconfig/grass76.pc -lgrass_gproj
  * usr/share/pkgconfig/grass76.pc -lgrass_raster
  * usr/share/pkgconfig/grass76.pc -lgrass_vector
  * usr/share/pkgconfig/grass76.pc -lgrass_dbmibase
  * usr/share/pkgconfig/grass76.pc -lgrass_dbmiclient
  * usr/share/pkgconfig/grass76.pc -lz
 The tag description is as follows:
    The specified pkg-config(1) file references a shared object via, for
    example, Libs: -lfoo but this package appears to not ship the
    associated "libfoo.so" shared library.
    This will result in a linker error and was likely caused by a missing
    installation step.
    Please ensure that your package ships the corresponding libfoo.so
    shared object file.
    Refer to the pkg-config(1) manual page and
    https://bugs.debian.org/919180 for details.
 Part of the problem is that the libraries are in a private directory like:
 ./usr/lib/grass76/lib/libgrass_gmath.7.6.so
 ./usr/lib/grass76/lib/libgrass_gmath.so -> libgrass_gmath.7.6.so
 And not having the .so symlink provided by the grass-dev package like for
 normal shared library packages.
 Another issue is that `-lm` & `-lz` should probably be moved from `Libs:`
 to `Libs.private:`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3787>
