[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
trac at osgeo.org
Sun Mar 10 15:55:18 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Another relevant issue are test datasets, it seems.
Some maps used in tests are not available in all sample data used for
testing (or with different names. If I remeber correctly, some effort has
been put on this relatively newly, as e.g. maps are copied to the correct
name used in the testsuite, before tests are run.
For example, in db/db.copy/testsuite/test_dbcopy.py the map "zipcodes" is
used, which is available in nc_basic, while a suitable map in nc_spm_08 is
named zipcodes_wake, the demolocation does not have a comparable map. The
documentation suggests to use nc_spm dataset for testing
(https://grass.osgeo.org/grass76/manuals/libpython/gunittest_testing.html).
Should tests (where necessary) be updated to work with nc_spm? (or should
input map names be chocen based on name of the location a test is ran in)?
I also had a look at how to skip tests (e.g. if maps are missing in the
location used to run tests). But could not figure out haow to do that.
Hints are welcome!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:7>
