[GRASS-dev] Translations and command description/options
Panagiotis Mavrogiorgos pmav99 at gmail.com
Mon Mar 11 10:49:29 PDT 2019
Not sure if there is any relation but just in case it proves useful:
I configure grass with:
./configure \
    --with-nls \
At the end of the configuration step I get the following output:
  NetCDF support:             no
  NLS support:                yes
  ODBC support:               no
Nevertheless, g.version -b seems to think otherwise:
g.version -b
GRASS 7.7.svn (2019)
 ./configure  --host=x86_64-linux-gnu --build=x86_64-linux-gnu
--target=x86_64-linux-gnu --prefix=/usr/lib --sysconfdir=/etc
--sharedstatedir=/var --enable-shared --enable-largefile=yes --with-x
--with-wxwidgets=/usr/bin/wx-config --without-blas --without-bzlib
--with-cxx --with-cairo --with-fftw --with-gdal --without-lapack
--without-liblas --without-mysql --without-netcdf *--without-nls*
--without-odbc
--with-opengl --without-openmp --with-png --without-pthread
--without-readline --with-regex --with-sqlite --with-tiff --disable-w11
--without-zstd --with-freetype
--with-freetype-includes=/usr/include/freetype2/ --without-geos ' '
--without-opencl --without-postgres --without-pdal
--with-proj-share=/usr/share/proj
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190311/874dc062/attachment.html>
