[GRASS-dev] Translations and command description/options
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Mon Mar 11 17:39:01 PDT 2019
On Mon, Mar 11, 2019 at 10:05 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> On Mon, Mar 11, 2019 at 6:49 PM Panagiotis Mavrogiorgos
> <pmav99 at gmail.com> wrote:
> > Not sure if there is any relation but just in case it proves useful:
> > I configure grass with:
> > ./configure \
> > --with-nls \
> > At the end of the configuration step I get the following output:
> > NetCDF support: no
> > NLS support: yes
> > ODBC support: no
> Can you please double check what's in config.log related to NLS?
Thank you Markus,
There is only a single line mentioning NLS:
*configure:12419: checking whether to use NLS*
I also attach the log file, in case it helps in debugging this.
> Funny idea:
> which grass77
> Please check for conflicting installations, or files not belonging to
> the user used to compile GRASS GIS (anecdote: in the past I got
> trapped because I commonly do not run "make install" but run it from
> bin.x86_64-pc-linux-gnu/grass77 and then I one day used "make install"
> and immediately forgot the day after that it was executed from
> /usr/local/...).
I don't have GRASS installed. I always run it from bin.x86_64-pc-linux-gnu
too.
What I do find most frustrating is that translations do work for the
"text-based splash screen" (which is printed by `lib/init/grass.py`) and
the GUI but not for the scripts directory:
https://asciinema.org/a/233110
with kind regards,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190312/2354def5/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190312/2354def5/attachment-0002.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190312/2354def5/attachment-0003.obj>
