[GRASS-dev] [GRASS GIS] #3413: r.in.gdal/v.in.ogr: add new config option to support GDAL/OGR configuration options
trac at osgeo.org
Tue Mar 12 11:32:47 PDT 2019
options
Reporter: mmetz | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.6.1
Component: Datasets | Version: svn-trunk
Resolution: fixed | Keywords: GDAL/OGR import
CPU: All | Platform: All
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
Closing as fixed because GDAL configuration options can now be provided to
r.in.gdal / v.in.ogr with the new gdal_config option in 7.6.
Regarding [r|v].external, a new ticket should be created because it
requires changes at library level.
While at it, v.external should also support a simple spatial filter with a
BBOX and where conditions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3413#comment:6>
