[GRASS-dev] gunittest and unicode
Anna Petrášová
kratochanna at gmail.com
Wed Mar 20 20:26:53 PDT 2019
On Fri, Mar 15, 2019 at 7:13 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Dear all,
> Recently, I have been looking into failing tests.
> A number of tests fail with “AssertionError: actual argument is not a
> string” [1]. These tests use “assertLooksLike”.
> The reason why the tests are failing is that stdout from “SimpleModule”
> deliveres unicode objects [2], while “assertLooksLike” only allows/expects
> str objects [3].
> In many cases, encoding stdout wth utf-8 (or wrapping it into str() like
> in [2]) would fix this.
> If you consider this an appropriate solution I can fix tests accordingly…
> Alternatively, assertLooksLike could be changed to accept Unicode (too)…
Generally, the rule is to expect unicode and deal with that, so in this
case check for str or unicode (use e.g.
https://stackoverflow.com/a/11301392/1058453)
Anna
> Let me know. I do like to contribute to getting a “green build” (as Panos
> put it), but I want to double check what the most appropriate solution is
> before I make any changes…
> And in particular I do not want to mess with stuff others are currently
> working on…
> BTW, it the nc_spm_full_v2alpha test data available somewhere?
> Cheers
> Stefan
> 1:
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2019-03-14-07-00/report_for_nc_spm_full_v2alpha_nc/vector/v.what/test_vwhat_ncspm/index.html
> 2:
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/gunittest/gmodules.py#L39
> 3:
> https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/gunittest/case.py#L179
> P.S.: The v.vect.stats test does not really test what it is supposed to
> test, which is why it does not fail although it also uses assertLooksLike:
> https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.vect.stats/testsuite/test_vect_stats.py#L63
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190320/e7bb2fa3/attachment.html>
