[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
GRASS GIS trac at osgeo.org
Wed Mar 27 11:04:02 PDT 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by pmav99):
 Note 1: Some tests require certain compilation options to be enabled (e.g.
 pdal, liblas etc). If support is missing the tests are failing. Ideally
 these tests should be skipped instead.
 Note 2: I did run the tests on an ubuntu VM where all the options were
 configured (except opencl and dwg). I did get several more failures than
 the ones reported
 [http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/index.html
 here]. More specifically on my VM:
 (SVN revision 74319)
 Executed 233 test files in 0:29:16.353563.
 From them 194 files (83%) were successful and 39 files (17%) failed.
 For comparison, the latest results from the test server are:
 (SVN revision 74304)
 Executed 233 test files in 0:36:57.428963.
 From them 216 files (93%) were successful and 17 files (7%) failed.
 I guess that this difference implies that the server is configured in a
 specific way which needs to be documented before we can replicate it on
 Travis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:15>
