[GRASS-dev] Import PostGIS vector layer into SQLite database
Markus Metz
markus.metz.giswork at gmail.com
Wed Mar 27 13:10:01 PDT 2019
On Wed, Mar 27, 2019 at 5:42 PM Luís Moreira de Sousa <
luis.de.sousa at protonmail.ch> wrote:
> Hi all,
> I am working with vector layers (points) composed of more than 100 000
geometries. These layers are originally in a PostGis database and I import
them with v.in.ogr, using a formulation like:
> v.in.ogr \
> input="PG:host=127.0.0.1 dbname=gisdb user=user password=secret" \
> layer=schema.points \
> output=points \
> -o --overwrite
> This command is successful, however, operations with the resulting points
layer are remarkably slow. For instance, this layer must be later loaded in
R and that operation alone is taking over 3 hours.
> After some back-and-forth testing, I identified the problem: v.in.ogr is
not saving its output in the internal GRASS SQLite database. Knowing this,
I can create a copy of the original output, that is automatically inserted
into the SQLite database, e.g.:
> g.copy vector=points,points_mirror
> Importing the points_mirror layer to R takes 3 minutes instead of 3
hours, for instance.
Which GRASS version are you using? This should not happen with recent
versions of GRASS 7.4 and 7.6.
Markus M
> While mirroring vectors imported with v.in.ogr solves the issue, it is an
inelegant solution that also takes up unnecessary space. I would prefer to
instruct v.in.ogr somehow to force it to use the SQLite database. I could
not find any reference in the manual, is it possible to do?
> Thank you.
> Email: luis.de.sousa at protonmail.ch
> RingID: ring:7ca91d83f4f9dec82fec9f1144b8e5c1ef2a110c
> URL: https://ldesousa.github.io
> Sent with ProtonMail Secure Email.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190327/4492acaa/attachment.html>
