[GRASS-dev] [GRASS GIS] #3771: Run tests on Travis
GRASS GIS trac at osgeo.org
Thu Mar 28 08:31:09 PDT 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Tests        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by sbl):
 Now multirunner also works with Python 3 and tests for P2 and P3 are more
 or less even...
 However, a new issue pops up:
 NameError: global name '_' is not defined
 Also, in Py3 I had to deactivate the following tests as the cause
 multirunner to freeze...
 lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py
 lib/python/temporal/testsuite/test_temporal_doctests.py
 temporal/t.vect.algebra/testsuite/test_vector_algebra.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3771#comment:18>
