[GRASS-dev] [release] 7.6.1
Martin Landa landa.martin at gmail.com
Fri Mar 29 03:02:50 PDT 2019
čt 28. 3. 2019 v 3:03 odesílatel Anna Petrášová <kratochanna at gmail.com> napsal:
>> Yes, well, that's bad. Build server is working, the problem is that
>> results are not transferred to publish server (wingrass.fsv.cvut.cz)
>> since IIS is broken on build server. I copied latest build manually
>> now, so latest builds are available [1]. Will fix IIS on build server
>> or set up opposite communication (build -> publish) ASAP.
service is back. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
