[GRASS-dev] [GRASS GIS] #3491: i.group cannot read from other mapsets
trac at osgeo.org
Wed May 1 00:54:01 PDT 2019
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.8.0
Component: Imagery | Version: unspecified
Resolution: fixed | Keywords: i.group
CPU: All | Platform: All
Changes (by marisn):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 sbl]:
> Partly fixed I would say:
No, this issue is completely fixed as it was about i.group.
> However, groups from other mapsets are still not fullly useable e.g. in
i.cluster.
> In addition, i.cluster seems to try to write to the imagery group
directory in the other mapset (the signature file), so further adjustments
downstreams seem to be required...
This is a different issue. Groups are designed to be useable only in the
current mapset. I changed i.group behaviour as I have new i. modules just
reading from and not writing to groups and thus being fine with current
changes. Other i. modules still follow the old design principles.
I am closing this issue as fixed. A discussion on group/subgroup behaviour
in context of i. modules writing their files into group should be held and
accordingly new issues should be opened per each module not matching
expected behaviour.
See also: #3525 and https://marc.info/?l=grass-dev&m=152474676813985&w=2
and https://marc.info/?l=grass-dev&m=152481635118286&w=2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:6>
