[GRASS-dev] [GRASS GIS] #3197: Memory limit issues with r.univar (when used within i.segment.stats)
trac at osgeo.org
Wed May 1 14:10:48 PDT 2019
Reporter: jpduffy | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.7
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: x86-32 | Platform: Linux
Comment (by mmetz):
Replying to [comment:4 martinl]:
> Still relevant?
Maybe there is a way to reduce memory consumption per zone, but still,
memory consumption increases with the number of zones. This will probably
not fix.
The addon r.univar2 needs to be reviewed and if regarded as an
improvement, modified to work also without zones.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3197#comment:5>
