[GRASS-dev] Benchmark the overhead of calling GRASS modules
Vaclav Petras wenzeslaus at gmail.com
Wed May 1 18:49:52 PDT 2019
Hi Panos and Markus,
I actually touched on this in my master's thesis [1, p. 54-58],
specifically on the subprocess call overhead (i.e. not import or
initialization overheads). I compared speed of calling subprocess in Python
to a Python function call. The reason was that I was calling GRASS modules
many times for small portions of my computational region, i.e. I was
changing region always to the area/object of interest within the actual
(user set) computational region. So, the overall process involved actually
many subprocess calls depending on the size of data. Unfortunately, I don't
have there a comparison of how the two cases (functions versus
subprocesses) would look like in terms of time spend for the whole process.
And speaking more generally, it seems to me that the functionality-CLI
coupling issue is what might me be partially fueling Facundo's GSoC
proposal (Python package for topology tools). There access to functionality
does not seem direct enough to the user-programmer with overhead of
subprocess call as well as related I/O cost, whether real or perceived,
playing a role.
Best,
Vaclav
[1] Petras V. 2013. Building detection from aerial images in GRASS GIS
environment. Master’s thesis. Czech Technical University in Prague.
http://geo.fsv.cvut.cz/proj/dp/2013/vaclav-petras-dp-2013.pdf
On Wed, May 1, 2019 at 6:03 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> Hi Panos,
> IMHO the overhead of calling GRASS modules is insignificant because it is
> in the range of milliseconds. I am much more concerned whether executing a
> GRASS module takes days or hours or minutes.
> Also note that the base of GRASS are C modules using the GRASS C library.
> GRASS python modules usually call GRASS C modules (or other GRASS python
> modules calling GRASS C modules). The first thing a GRASS Python module
> does is calling the GRASS C module g.parser, after that it calls (in the
> end) some other GRASS C modules. That means it is not straightforward to
> test the overhead of calling GRASS Python modules vs calling GRASS C
> modules because it is really GRASS Python + C modules vs GRASS C modules
> only. And the overhead is insignificant (not measurable) compared to actual
> execution time for larger datasets/regions.
> Markus M
> On Mon, Apr 29, 2019 at 8:49 AM Panagiotis Mavrogiorgos <pmav99 at gmail.com>
> wrote:
>> Hello all
>> You might find it easier to read the following text i
>> <https://gist.github.com/pmav99/8f4546fe15940b3cb7db0cfb65e18d33>n a gist
>> ## Introduction
>> I was trying to write a decorator/contextmanager that would temporary
>> change the
>> computational region, but while using it I noticed that there was some
>> overhead the root
>> of which seemed to be the usage of the GRASS modules. So in order to
>> quantify this
>> I wrote a small benchmark that tries to measure the overhead of calling a
>> GRASS Module.
>> This is what I found.
>> ## tl;dr
>> Calling a GRASS module incurs a constant but measurable overhead which,
>> in certain
>> cases, e.g. when writing a module that uses a lot of the other modules,
>> can quickly
>> add up to a significant quantity.
>> ## Disclaimer
>> If you try to run the benchmark on your own PC, the actual timings you
>> will get will
>> probably be different. The differences might be caused by having:
>> - a stronger/weaker CPU
>> - faster/slower hard disk.
>> - using different Python version
>> - using different compilation flags
>> Still, I think that some of the findings are reproducible.
>> For reference, I used:
>> - OS: Linux 5.0.9
>> - CPU: Intel i7 6700HQ
>> - Disk type: SSD
>> - Python: 3.7
>> - `CFLAGS='-O2 -fPIC -march=native -std=gnu99'`
>> ## Demonstration
>> The easiest way to demonstrate the performance difference between using a
>> GRASS module
>> vs using the GRASS API is to run the following snippets.
>> Both of them do exactly the same thing, i.e. retrieve the current region
>> settings 10
>> times in a row.  The performance difference is huge though. On my laptop,
>> the first one
>> needs 0.36 seconds while the second one needs just 0.00038 seconds.
>> That's almost
>> a 1000x difference...
>> ``` python
>> import time
>> import grass.script as gscript
>> start = time.time()
>> for i in range(10):
>>     region = gscript.parse_command("g.region", flags="g")
>> end = time.time()
>> total = end - start
>> print("Total time: %s" % total)
>> vs
>> ``` python
>> import time
>> from grass.pygrass.gis.region import Region
>> start = time.time()
>> for i in range(10):
>>     region = Region()
>> end = time.time()
>> total = end - start
>> ## How much is the overhead exactly?
>> In order to measure the actual overhead of calling a GRASS module, I
>> created two new
>> GRASS modules that all they do is parse the command line arguments and
>> measured how much
>> time is needed for their execution. The first module is [`r.simple`]()
>> and is
>> implemented in Python while the other one is [`r.simple.c`]() and is
>> implemented in C.
>> The timings are in msec and the benchmark was executed using Python 3.7
>> | call method                    | r.simple | r.simple.c |
>> | pygrass.module.Module          |   85.9   |    66.5    |
>> | pygrass.module.Module.shortcut |   85.5   |    66.9    |
>> | grass.script.run_command       |   41.3   |    30.5    |
>> | subprocess.check_call          |   41.8   |    30.3    |
>> As we can see, `gsrcipt.run_command` and `subprocess` give more or less a
>> identical
>> results, which is to be expected since `run_command` + friends are just a
>> thin wrapper
>> around `subprocess`.  Similarly `shortcuts` has the same overhead as
>> "vanila"
>> `pygrass.Module`.  Nevertheless, it is obvious that `pygrass` is roughly
>> 2x times slower
>> than `grass.script` (but more about that later).
>> As far as C vs Python goes, on my computer modules implemented in C seem
>> to be 25% faster than their
>> Python counterparts.  Nevertheless, a 40 msec startup time doesn't seem
>> extraordinary
>> for a Python script, while 30 msec feels rather large for a CLI
>> application implemented
>> in C.
>> ## Where is all that time being spent?
>> ### C Modules
>> Unfortunately, I am not familiar enough with the GRASS internals to
>> easily check what is
>> going on and I didn't have the time to try to profile the code. I suspect
>> that
>> `G_gisinit` or something similar is causing the overhead, but someone
>> more familiar with
>> the C API should be able to enlighten us.
>> ### Python Modules
>> In order to gain a better understanding of the overhead we have when
>> calling python
>> modules, we also need to measure the following quantities:
>> 1. The time that python needs to spawn a new process
>> 2. The startup time for the python interpreter
>> 3. The time that python needs to `import grass`
>> These are the results:
>> |                         | msec |
>> | subprocess spawn        |  1.2 |
>> | python 2 startup        |  9.0 |
>> | python 2 + import grass | 24.5 |
>> | python 3 startup        | 18.2 |
>> | python 3 + import grass | 39.3 |
>> As we can see:
>> - the overhead of spawning a new process from within python is more or
>> less negligible
>>   (at least compared to the other quantities).
>> - The overhead of spawning a python 3 interpreter is 2x bigger than
>> Python 2; i.e.  the
>>   transition to Python 3 will have some performance impact, no matter
>> what.
>> - The overhead of spawning a python 3 interpreter accounts for roughly
>> 50% of the total
>>   overhead (18 msec out of 41 msec).
>> - The other 50% of the overhead is pretty much caused just by importing
>> the `grass`
>>   library.
>> ## Why is Pygrass 2x times slower?
>> I haven't carefully looked into this (i.e. I haven't profiled the code),
>> but it seems
>> that the culprit is [this
>> line](
>> https://github.com/GRASS-GIS/grass-ci/blob/fe814a4fb73937ce96a36c11b6876db42acf28fa/lib/python/pygrass/modules/interface/module.py#L528
>> In other words, `pygrass` calls a module twice, once to get the
>> interface's description
>> and once to actually run the module. That's why the overhead is double
>> both for
>> C modules and Python ones.
>> ## Is this truly a problem?
>> Well, it depends :)
>> The most important factor is probably the size of the computational
>> region.  If you are
>> dealing with really large regions, then the overhead is probably
>> miniscule. If you are
>> dealing with much smaller ones though, then it can be significant.
>> That being said, there are at least two cases where I think that this
>> overhead is
>> important:
>> - interactive sessions
>> - running tests
>> Just to give an example, `i.pansharpen` calls ~50 other GRASS modules. On
>> my laptop, the
>> overhead for these calls is almost 2 seconds. Is this a lot? Well, if you
>> are
>> pansharpening Landsat Tiles, it probably is not that much, but you will
>> have this
>> overhead even if you are pansharpening a 4 pixel map (e.g. when running
>> tests).
>> I am pretty sure that there are numerous other modules that are just like
>> that, too.
>> ## What is to be done?
>> I think that there are two different areas where work can be done:
>> 1. Reduce the actual overhead; i.e. make calling GRASS modules faster.
>> 2. Convert calls to GRASS modules with API calls which, as shown earlier,
>> are orders of
>>    magnitude faster.
>> ### Reduce the overhead
>> The overhead of Python and C modules has different causes.
>> As I said, I haven't looked into what causes C modules to take so long so
>> i can't make
>> any suggestions. This should be further looked into though. The reason is
>> that modules
>> like e.g. `g.region` are being used practically everywhere, so speeding
>> these up should
>> give a measureable performance improvement.
>> As far as Python modules go, unfortunately, the overhead seems to be
>> relatively
>> inelastic.  Speeding up the startup time of the Python interpreter is not
>> something that
>> GRASS can do or rely upon. So, the only thing that can be actually be
>> done is to try to
>> reduce the time needed for importing the `grass` library. That being
>> said, this should
>> probably not skim more than a few ms at best, but at least the gains
>> should be there for
>> all python modules.
>> Luckily there is at least one relatively low hanging fruit. Speeding
>> pygrass should not
>> be that difficult. I haven't looked into this but pre-generating the
>> modules' XML
>> descriptions seems feasible and it should remove the need to call each
>> module twice,
>> thus making pygrass performance comparable to `grass.script.run_command`
>> ### Convert module calls to API calls
>> Converting the module calls to API calls is what can potentially give the
>> bigger
>> benefits, but at the same time is what needs the most work.
>> There are some low hanging fruits here too. E.g. functions like
>> `use_temp_region()` and
>> `raster_info()` can probably be refactored to use the pygrass API, while
>> calls to e.g.
>> `g.region` can probably be replaced with `pygrass.gis.Region` objects etc.
>> Nevertheless, this does not really touch the root of the problem which
>> IMHV is the tight
>> coupling between the GRASS modules functionality and the CLI. In layman
>> terms, at the
>> moment, if you want to use module A from module B you are forced to spawn
>> a new process
>> and suffer the overhead that this entails.
>> TBH, I am not sure if this a problem that can even be tackled at this
>> stage, but if each
>> module had one or more functions that could be imported/called by other
>> modules,
>> everything would be much easier and performance would be significantly
>> better.
>> ## How to run the benchmark?
>> If you want to run this benchmark on your own you need to:
>> 1. `git remote add panos https://github.com/pmav99/grass-ci.git`
>> <https://github.com/pmav99/grass-ci.git>
>> 1. `git fetch --all`
>> 1. `git checkout overhead`
>> 1. `cd scripts/r.simple && make && cd ../../`
>> 1. `cd raster/r.simple.c && make && cd ../../`
>> 1. Start a grass session
>> 1. `python benchmark.py`
>> I haven't run the benchmark under Python 2, but even if there are
>> incompatibilities,
>> they should be trivial to fix.
>> I will be happy to hear any remarks :)
>> with kind regards,
>> Panos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190501/f2a79cbb/attachment-0001.html>
