[GRASS-dev] [GRASS GIS] #3235: Vect_cidx_find_all should not allow mixing GV_AREA with other geometries
trac at osgeo.org
Thu May 2 01:37:50 PDT 2019
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.6.2
Component: LibVector | Version: svn-trunk
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Unspecified
Changes (by mmetz):
* milestone: 8.0.0 => 7.6.2
Comment:
Replying to [comment:12 neteler]:
> Replying to [comment:11 mmetz]:
> > Modules using `Vect_cidx_find_all()` are v.profile, v.out.ogr,
v.db.select, v.net, v.edit, and none of them mixes GV_AREA with other
geometries. A fatal error will occur if a new module does mix GV_AREA with
other geometries when calling `Vect_cidx_find_all()` (programmer's error).
> Then the bug report needs to be reopened again since we didn't reach
8.0.0 yet.
> Say, closing it with changes applied to 7.6.2 while the milestone is 8
is confusing (for me)...
Sorry, that was trac confusion because we were editing the same time.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3235#comment:13>
