[GRASS-dev] Which is the correct WIND convention for creating a new mapset?
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Mon May 6 09:21:39 PDT 2019
Hello all,
I am a bit confused WRT what the expected WIND should be when you create a
new mapset.
Some functions copy DEFAULT_WIND from PERMANENT. E.g.:
- lib/gis/make_mapset.c
<https://github.com/GRASS-GIS/grass-ci/blob/686364f6a5dd65f4a0a79b71cd29a997489eda7d/lib/gis/make_mapset.c#L85-L86>
- pygrass.gis.make_mapset()
<https://github.com/GRASS-GIS/grass-ci/blob/686364f6a5dd65f4a0a79b71cd29a997489eda7d/lib/python/pygrass/gis/__init__.py#L112>
- the grass executable
<https://github.com/GRASS-GIS/grass-ci/blob/686364f6a5dd65f4a0a79b71cd29a997489eda7d/lib/init/grass.py#L1072-L1076>
While others copy WIND from PERMANENT. E.g.
- the tests
<https://github.com/GRASS-GIS/grass-ci/blob/686364f6a5dd65f4a0a79b71cd29a997489eda7d/lib/python/gunittest/invoker.py#L124-L125>
- gui.wxpython.startup.create_mapset()
<https://github.com/GRASS-GIS/grass-ci/blob/686364f6a5dd65f4a0a79b71cd29a997489eda7d/gui/wxpython/startup/utils.py#L78-L82>
Is there an established convention?
with kind regards,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190506/25823c5b/attachment-0001.html>
