[GRASS-dev] [GRASS GIS] #3841: script/core.py: create_location() fails with FileNotFoundError: [Errno 2] No such file or directory: '/tmp/grass7-root-94/tmploc/PERMANENT/MYNAME'
GRASS GIS trac at osgeo.org
Thu May 9 13:34:52 PDT 2019
 Reporter:  neteler            |      Owner:  grass-dev@…
     Type:  defect             |     Status:  new
 Priority:  normal             |  Milestone:  7.8.0
Component:  Python             |    Version:  svn-trunk
 Keywords:  python3, grass.py  |        CPU:  x86-64
 Platform:  Linux              |
 In a docker environment (Ubuntu 18:04 based) I get this startup error with
 trunk (on a pure Python 3 environment):
 # note: the second line from bottom is local debug output via print()
 root at 6ade79b80a2b:/grassdb# grass --tmp-location EPSG:25832 --exec
 g.extension -s extension=i.sentinel url=/src/i.sentinel
 Starting GRASS GIS...
 Creating new GRASS GIS location <tmploc>...
 /tmp/grass7-root-37 tmploc EPSG:25832
 ERROR: FileNotFoundError(2, 'No such file or directory')
 With Python debugger (pdb) I see that it cannot open a file with
 `codecs.open()`:
 /tmp/grass7-root-94 tmploc EPSG:25832
 25832 None
 > /usr/local/bin/grass(853)create_location()
 -> gcore.create_location(gisdbase, location,
 (Pdb) s
 > /usr/local/bin/grass(854)create_location()
 -> epsg=epsg, datum_trans=datum_trans)
 (Pdb) s
 --Call--
 /usr/local/grass77/etc/python/grass/script/core.py(1518)create_location()
 -> def create_location(dbase, location, epsg=None, proj4=None,
 filename=None,
 (Pdb) s
 /usr/local/grass77/etc/python/grass/script/core.py(1538)create_location()
 -> gisdbase = None
 (Pdb) s
 /usr/local/grass77/etc/python/grass/script/core.py(1539)create_location()
 -> if epsg or proj4 or filename or wkt:
 (Pdb) s
 /usr/local/grass77/etc/python/grass/script/core.py(1541)create_location()
 -> gisdbase = gisenv()['GISDBASE']
 (Pdb) s
 --Call--
 > /usr/local/grass77/etc/python/grass/script/core.py(1075)gisenv()
 -> def gisenv(env=None):
 (Pdb) s
 > /usr/local/grass77/etc/python/grass/script/core.py(1086)gisenv()
 -> s = read_command("g.gisenv", flags='n', env=env)
 (Pdb) s
 --Call--
 > /usr/local/grass77/etc/python/grass/script/core.py(491)read_command()
 -> def read_command(*args, **kwargs):
 (Pdb) s
 > /usr/local/grass77/etc/python/grass/script/core.py(500)read_command()
 -> encoding = 'default'
 (Pdb) s
 > /usr/local/grass77/etc/python/grass/script/core.py(501)read_command()
 -> if 'encoding' in kwargs:
 (Pdb) s
 > /usr/local/grass77/etc/python/grass/script/core.py(504)read_command()
 -> if _capture_stderr and 'stderr' not in kwargs.keys():
 (Pdb) s
 > /usr/local/grass77/etc/python/grass/script/core.py(506)read_command()
 -> process = pipe_command(*args, **kwargs)
 > /usr/local/grass77/etc/python/grass/script/core.py(512)read_command()
 -> if _capture_stderr and returncode:
 (Pdb) n
 > /usr/local/grass77/etc/python/grass/script/core.py(514)read_command()
 -> return handle_errors(returncode, stdout, args, kwargs)
 (Pdb) n
 --Return--
 /usr/local/grass77/etc/python/grass/script/core.py(514)read_command()->'GISDBASE=/gr...T=<UNKNOWN>\n'
 (Pdb) n
 > /usr/local/grass77/etc/python/grass/script/core.py(1087)gisenv()
 -> return parse_key_val(s)
 (Pdb) n
 --Return--
 /usr/local/grass77/etc/python/grass/script/core.py(1087)gisenv()->{'GISDBASE':
 ...: '<UNKNOWN>'}
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1542)create_location()
 -> run_command('g.gisenv', set='GISDBASE=%s' % dbase)
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1544)create_location()
 -> if not os.path.exists(dbase):
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1548)create_location()
 -> if os.path.exists(os.path.join(dbase, location)):
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1556)create_location()
 -> kwargs = dict()
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1557)create_location()
 -> if datum:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1559)create_location()
 -> if datum_trans:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1562)create_location()
 -> if epsg:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1563)create_location()
 -> ps = pipe_command('g.proj', quiet=True, flags='t', epsg=epsg,
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1564)create_location()
 -> location=location, stderr=PIPE, **kwargs)
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1577)create_location()
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1578)create_location()
 -> error = ps.communicate()[1]
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1579)create_location()
 -> run_command('g.gisenv', set='GISDBASE=%s' % gisdbase)
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1581)create_location()
 -> if ps.returncode != 0 and error:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1584)create_location()
 -> try:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1585)create_location()
 -> fd = codecs.open(os.path.join(dbase, location, 'PERMANENT', 'MYNAME'),
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1586)create_location()
 -> encoding='utf-8', mode='w')
 (Pdb) n
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1592)create_location()
 -> except OSError as e:
 (Pdb) n
 /usr/local/grass77/etc/python/grass/script/core.py(1593)create_location()
 -> raise ScriptError(repr(e))
 (Pdb) n
 grass.exceptions.ScriptError: FileNotFoundError(2, 'No such file or
 directory')
 (Pdb) n
 --Return--
 /usr/local/grass77/etc/python/grass/script/core.py(1593)create_location()->None
 (Pdb) n
 directory')
 (Pdb) n
 > /usr/local/bin/grass(864)create_location()
 -> except gcore.ScriptError as err:
 (Pdb) n
 > /usr/local/bin/grass(865)create_location()
 -> fatal(err.value.strip('"').strip("'").replace('\\n', os.linesep))
 (Pdb) n
 SystemExit: Exiting...
 (Pdb) n
 --Return--
 > /usr/local/bin/grass(865)create_location()->None
 The code in question:
 https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/core.py#L1573
 1573        try:
 1574            fd = codecs.open(os.path.join(dbase, location,
 1575                             encoding='utf-8', mode='w')
 1576            if desc:
 1577                fd.write(desc + os.linesep)
 1578            else:
 1579                fd.write(os.linesep)
 1580            fd.close()
 1581        except OSError as e:
 1582            raise ScriptError(repr(e))
 Version used:
 lsb_release -a
 No LSB modules are available.
 Distributor ID: Ubuntu
 Description:    Ubuntu 18.04.2 LTS
 Release:        18.04
 Codename:       bionic
 python3 --version
 Python 3.6.7
 Any ideas here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3841>
