[GRASS-dev] [GRASS GIS] #2525: Unable to open sqlite database if path contains non-latin letters
GRASS GIS trac at osgeo.org
Fri May 10 00:52:59 PDT 2019
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.6.2
 Component:  wxGUI        |    Version:  svn-releasebranch70
Resolution:               |   Keywords:  attribute
       CPU:  Unspecified  |   Platform:  MSWindows Vista
Comment (by marisn):
 Replying to [comment:13 sbl]:
 > In 7.6, the state is actually worse, if the mapset contains non-ascii
 characters...
 Mapset names should not contain non-ascii chars. This issue was about
 cases when mapset name is OK, but path leading to it contains non-ascii
 chars.
 Unfortunately I could not test the issue as GRASS failed to start on
 Windows at all due to #3837
Ticket URL: <https://trac.osgeo.org/grass/ticket/2525#comment:14>
