[GRASS-dev] svn/trac -> git/github migration plan
Helmut Kudrnovsky
hellik at web.de
Fri May 10 04:12:56 PDT 2019
Hi Vero,
>See Martin's original mail and links. The tickets that need to be >reviewed
are those with milestone 7.0.7 and 7.2.4, as to know if >they are still
valid and milestone should be moved to 7.6.2
IMHO when I go through the tickets for 7.0.7 and 7.2.4, an additional check
with trunk (Python 3) could be done at the same time and may save resources
later on to decide if a fix should go to 7.6 /7.8 or maybe only to 7.8 cause
of a different code base (py2 vs py3) and/or focus on 7.8 only
so far I couldn't find a solution for the winGRASS trunk regression
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
