[GRASS-dev] [GRASS GIS] #3837: OSGeo4W winGRASS77svn - startup error: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
GRASS GIS trac at osgeo.org
Sat May 11 02:36:09 PDT 2019
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.8.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  python3, py3, wingrass
       CPU:  Unspecified  |   Platform:  MSWindows
Comment (by hellik):
 Replying to [comment:6 hellik]
 > with r74474
 > C:\>g.gui wxpython
 > Launching <wxpython> GUI in the background, please wait...
 > Traceback (most recent call last):
 >   File "C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py", line 32,
 in <module>
 >     from core import globalvar
 >   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\globalvar.py",
 line 35, in <module>
 >     from core.debug import Debug
 >   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line
 77, in <module>
 >     Debug = DebugMsg()
 39, in __init__
 >     self.SetLevel()
 45, in SetLevel
 >     self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
 >   File "C:\OSGEO4~1\apps\grass\grass77\etc\python\grass\script\core.py",
 line 1075, in gisenv
 >     s = read_command("g.gisenv", flags='n', env=env)
 line 495, in read_command
 >     process = pipe_command(*args, **kwargs)
 line 464, in pipe_command
 >     return start_command(*args, **kwargs)
 line 394, in start_command
 >     return Popen(args, **popts)
 line 54, in __init__
 >     cmd = shutil_which(args[0])
 >   File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in which
 >     if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
 <genexpr>
 starting the GUI
 Starting GRASS GIS...
   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\gis_set.py", line 34,
 in <module>
 77, in <module>
     Debug = DebugMsg()
 39, in __init__
     self.SetLevel()
 45, in SetLevel
   File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in <genexpr>
 ERROR: Error in GUI startup. See messages above (if any) and if necessary,
 please report this error to the GRASS developers.
 On systems with package manager, make sure you have the right GUI package,
 probably named grass-gui, installed.
 To run GRASS GIS in text mode use the --text flag.
 Use '--help' for further options
      grass77 --help
 See also: https://grass.osgeo.org/grass77/manuals/helptext.html
 Exiting...
 Drücken Sie eine beliebige Taste . . .
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:7>
