[GRASS-dev] [GRASS GIS] #3837: OSGeo4W winGRASS77svn - startup error: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
GRASS GIS trac at osgeo.org
Sat May 11 13:24:32 PDT 2019
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.8.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  python3, py3, wingrass
       CPU:  Unspecified  |   Platform:  MSWindows
Comment (by hellik):
 Replying to [comment:14 pmav99]:
 > OK, it seems that this will be probably fixed on Python 3.8:
 > - https://bugs.python.org/issue18283
 https://github.com/python/cpython/commit/5680f6546dcda550ad70eefa0a5ebf1375303307
 > In the meantime, @hellik can you please try to copy paste the 3.8
 version of shutil.which from github and test if it works?
 https://github.com/python/cpython/blob/d8320ecb86da8df7c13d8bf8582507f736aa2924/Lib/shutil.py#L1293-L1369
 now what I've done:
 *  I copied ''def which'' and ''def _access_check'' (L1285-L1369) from
 [https://github.com/python/cpython/commit/5680f6546dcda550ad70eefa0a5ebf1375303307
 python github] into C:\OSGeo4W64\apps\Python37\lib\shutil.py
 => the wxGUI start up window to select a location/mapset pops up.
 thus, the python fix for 3.8 (''shutil.which() should support bytes'')
 seems to work.
 then there is another issue (in
 C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py), but then this may
 be another ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:16>
