[GRASS-dev] svn/trac -> git/github migration plan
Moritz Lennert
mlennert at club.worldonline.be
Mon May 13 04:21:21 PDT 2019
On 12/05/19 18:19, Markus Neteler wrote:
> On Fri, May 10, 2019 at 5:06 PM Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> Ășt 7. 5. 2019 v 10:26 odesĂlatel Martin Landa <landa.martin at gmail.com> napsal:
>>> commits can be referenced to github issues. Issue migration needs to
>>> be also done on private repository. This would require to set up empty
>>> private repo, migrate tickets and than transfer ticket using GitHub
>>> API to public repo. This complicates procedure a bit. I would still
>>> prefer to do source code and issues migration together even it will
>>> take some time.
>> back to this topic, I added to trac an alternative scenario based on
>> two steps (source code and issues migration separated) [1]. Opinions
>> welcome. We are very close to day D.
> Excellent.
> IMHO the separate migration of source code and issues is the way to go.
> Like that we can already work with the then completed migration next
> weekend in Berlin and define workflows.
+1
I think we just need to get the ball rolling. There will certainly be
some transition pain, but if we try to prepare everything to perfection
it will never happen ;-)
Moritz
