[GRASS-dev] svn/trac -> git/github migration plan
Martin Landa
landa.martin at gmail.com
Mon May 13 06:24:05 PDT 2019
po 13. 5. 2019 v 15:01 odesÃlatel Martin Landa <landa.martin at gmail.com> napsal:
r74440 = 1f1209cbe0074f1e6451b4ed40f56a22192724e7 (refs/remotes/origin/trunk)
M raster/r.to.vect/areas_io.c
M raster/r.to.vect/lines.c
M raster/r.to.vect/lines_io.c
r74441 = 2fb78d92ee0ad2570a4388b30aeb3cdc63326cdb (refs/remotes/origin/trunk)
M raster/r.thin/thin_lines.c
r74442 = a3741bbbdfc31118ea9ab9d98a6bd15a39b6fa83 (refs/remotes/origin/trunk)
Error from SVN, (160006): Invalid filesystem revision number: No such
revision 74542
it seems that it fails to grab r74442 when it starts to speak
surprisingly about non-existing. But this works:
$ svn log file:///opt/osgeo/svn/repos/grass/grass
r74443 | mmetz | 2019-04-30 20:28:34 +0200 (Tue, 30 Apr 2019) | 1 line
r.thin: avoid integer overflow, remove unused variable (backport trunk r74442)
r74442 | mmetz | 2019-04-30 20:26:10 +0200 (Tue, 30 Apr 2019) | 1 line
I run `git svn fetch` many times when doing various tests. I have no
idea what could be wrong at this moment. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
