[GRASS-dev] [GRASS GIS] #3847: Bivariate scatterplot mapset handling and color preferences
trac at osgeo.org
Wed May 15 10:36:43 PDT 2019
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-releasebranch76
Keywords: scatterplot | CPU: x86-64
Platform: Linux |
The wxGUI bivariate scatterplot tool works with maps with the same name,
but in different mapsets. However, it does not when generating / exporting
regression statistics. It will only generate statistics for the map in the
mapset that comes first alphabetically, despite displaying a scatterplot
for a different set of maps.
Mapset handling is also an issue for the r.scatterplot add-on. Here it is
more serious. Maps of the same name, but in different mapsets only create
scatterplots for the first mapset alphabetically.
r.scatterplot input=map at a,map at b,map at c output=scatterplot
Also, most preferences for the bivariate scatterplot tool save
successfully, but the color for points does not. It always returns to the
default blue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3847>
