Anna Petrášová wrote > Did you compile it with those local changes? It needs to be compiled to > create the xml files. no compilation yet, just copied the updated python script. which is the relevant xml-file? ----- best regards Helmut -- Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
