[GRASS-dev] GRASS GIS on an Alpine Linux docker
Markus Neteler
neteler at osgeo.org
Wed May 15 13:34:11 PDT 2019
Hi again,
On Wed, May 15, 2019 at 3:18 PM Pietro <peter.zamb at gmail.com> wrote:
> Dear all,
> Recently I've started looking for a docker image with GRASS, I'm looking for a minimal image that is as small as possible.
> From my test the other images available where always above 1GB of size, the current version once built have a size of ~220 MB.
> Another difference respect to others dockers available that I found is that it is possible to select which version use when building the image:
> sudo docker build --build-arg GRASS_VERSION=7.7 \
> --build-arg PYTHON_VERSION=3 \
> --build-arg PROJ_VERSION=5.2.0 \
> --build-arg PROJ_DATUMGRID_VERSION=1.8 \
> --volume \
> zarch/alpine-grass-gis
> You can find the repository here:
> https://github.com/zarch/docker-alpine-grass-gis
> Do you have any feedback?
It looks much better now than my old attempts - thank you :)
> Any hint to improve the `Dockerfile` or the `README.md` are welcome. :-)
I'll give it a try as will report back.
Best
Markus
> Thank you for the support.
> Best regards
> Pietro
