[GRASS-dev] [GRASS GIS] #3838: r74307 breaks GUI: UnicodeDecodeError
GRASS GIS trac at osgeo.org
Fri May 17 02:29:34 PDT 2019
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by pmav99):
 I just tried the following using Python 2 both at trunk and at r74305.
 There were no tracebacks in either case.
 $ LC_ALL=fr_FR.UTF-8 ./run_grass.sh ~/gdata2/nc_spm_full_v2alpha/PERMANENT
 --text
           __________  ___   __________    _______________
          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
        \____/_/ |_/_/  |_/____/____/   \____/___//____/
 Bienvenue dans le SIG GRASS 7.7.svn (exported)
 Page d'accueil du SIG GRASS :            https://grass.osgeo.org
 Cette version fonctionne avec :          Z Shell (/usr/bin/zsh)
 L'aide est disponible par la commande :  g.manual -i
 Voir les termes de la licence avec :     g.version -c
 Voir les termes de la licence avec :     g.version -x
 Démarrer l'interface graphique avec :   g.gui wxpython
 Lors prêt pour la fermeture entrer :    exit
 $ d.mon -l
 No monitors running
 $ d.mon start=wx0
 12:22:59: Warning: Mismatch between the program and library build versions
 detected.
 The library used 3.0 (wchar_t,compiler with C++ ABI 1013,wx
 containers,compatible with 2.8),
 and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1011,wx
 containers,compatible with 2.8).
 /usr/lib64/python2.7/site-packages/wx-3.0-gtk3/wx/_core.py:16629:
 UserWarning: wxPython/wxWidgets release number mismatch
   warnings.warn("wxPython/wxWidgets release number mismatch")
 $ d.rast basin
  100%
 Since the original traceback has been resolved, I would suggest opening a
 new ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3838#comment:13>
