[GRASS-dev] [GRASS GIS] #3851: r.out.mpeg always fails because the output file name is empty
trac at osgeo.org
Wed May 22 02:51:37 PDT 2019
Reporter: paoloz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Keywords: mpeg animation | CPU: Unspecified
Platform: Unspecified |
Testing r.out.mpeg using North Carolina data set, smaller subset NC
location (nc_basic_spm_grass7)
g.region rast=elevation
r.out.mpeg view1=elevation at PERMANENT,elevation_shade at PERMANENT
output=./test.mpg
always fails with
output=./test.mpg
Reading raster map <elevation at PERMANENT>...\\
Reading raster map <elevation_shade at PERMANENT>...\\
ERROR: Could not open output file! \\
WARNING: mpeg_encode ERROR
the reason is that the name of the output mpeg fie is not copied in the
"outfile" variable, which is used to write the name of the output mpeg in
the configuration file for "ppmtompeg"|"mpeg_encode" encoder. Therefore
the name of the output mpeg is blank and the encoding always fail with
"ERROR: Could not open output file!".
Tested with GRASS: 7.0.0, 7.4 svn (12/01/2018), 7.6.0, 7.6.1.
Works in 6.4.6 because the variable is not empty, see lines 442-445 of
grass-6.4.6/raster/r.out.mpeg/main.c.
A patch to solve the problem is attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3851>
